Ga door naar hoofdinhoud
Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement
Wat je nodig hebt
  1. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement, Vacuum Battery: stap 1, afbeelding 1 van 2 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement, Vacuum Battery: stap 1, afbeelding 2 van 2
    • Orient the device upside-down
    • Remove two 15 mm screws using a Phillips #1 screwdriver.
    • Remove the battery cover.
  2. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 2, afbeelding 1 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 2, afbeelding 2 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 2, afbeelding 3 van 3
    • Using the two paper tabs on each side of the battery, slide it up and out of the robot.
    • Using an opening tool, disconnect the wire connector from the robot.
    • Remove the battery.
  3. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement, Vacuum Brush Motor: stap 3, afbeelding 1 van 2 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement, Vacuum Brush Motor: stap 3, afbeelding 2 van 2
    • Remove the debris container.
    • Remove the main brush cover from the vacuum to expose the roller.
  4. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 4, afbeelding 1 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 4, afbeelding 2 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 4, afbeelding 3 van 3
    • To remove the main brush, grab the non-orange side and simply lift up and out of orange connector.
    • Remove two 8mm screws using the TR9 screwdriver on orange piece.
    • Remove the one 12mm screw that is located inside the main brush.
    • Screws may have some Loctite residue. Remove all screws with caution as to not strip the heads.
  5. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 5, afbeelding 1 van 1
    • Using the TR15 Screwdriver, remove the five 11mm screws surrounding the drive wheel.
    • Gently pull the wheel assembly out.
    • Make sure to pull lightly on the wheel assembly to ensure wires do not rip apart.
    • Repeat for other drive wheel.
  6. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 6, afbeelding 1 van 2 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 12mm screws on either side of the swivel wheel using the TR15 screwdriver.
    • Remove the other three 12mm screws that surround the base.
  7. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 7, afbeelding 1 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 7, afbeelding 2 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 7, afbeelding 3 van 3
    • Remove six 8mm screws using the TR9 screwdriver.
    • Separate the bottom of the bumper from the top by simply pulling them apart or using the spudger.
    • Remove both pieces of the bumper from the vacuum.
  8. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 8, afbeelding 1 van 2 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 8, afbeelding 2 van 2
    • Orient the device to be right side up.
    • Remove the top of the vacuum and separate the power cable.
    • Carefully pull up the top to not rip any wires out.
  9. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 9, afbeelding 1 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 9, afbeelding 2 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the wires that are hooked above the motor.
    • Remove the two 8mm screws that are holding the motor to the vacuum using the Phillips #1 screwdriver.
    • Using tweezers, separate the power wire from the motherboard.
  10. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 10, afbeelding 1 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 10, afbeelding 2 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 10, afbeelding 3 van 3
    • Remove the motor from the vacuum.
    • The wire might be under other wires. Careful when removing to not tear or dislodge other wires.
    • Remove the three 8mm screw using the Phillips #1 screwdriver.
    • Separate the cover from the gearbox.
  11. Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 11, afbeelding 1 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 11, afbeelding 2 van 3 Shark AI Ultra AV2511AE Vacuum Brush Motor Replacement: stap 11, afbeelding 3 van 3
    • Remove the belt from the gears using pliers.
    • Remove the two 5mm screws using the Phillips #1 screwdriver.
    • If holding vertically, the motor will fall out once the screws are removed.
    • Separate the motor from the gearbox.
Conclusie
Frankie Medina
325 Reputatie
3 handleidingen geschreven
Utah Tech University, Team 1-3, McMurrin Fall 2023 Lid van Utah Tech University, Team 1-3, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G3
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 69
Altijd: 401
