Ga door naar hoofdinhoud
Shark AI Ultra AV2511AE Drive Wheel Motor Replacement
Wat je nodig hebt
  1. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: stap 1, afbeelding 1 van 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: stap 1, afbeelding 2 van 2
    • Put the device with the wheel side up.
    • Remove the five 11 mm screws surrounding the drive wheel using a Torx TR15 screwdriver.
    • Gently pull the wheel assembly out.
    • Make sure to pull lightly on the wheel assembly to ensure wires do not rip apart.
  2. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 2, afbeelding 1 van 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 2, afbeelding 2 van 2
    • Separate the wire connector from the wheel assembly using an opening tool.
  3. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 3, afbeelding 1 van 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 3, afbeelding 2 van 2
    • Remove the spring from the wheel assembly.
  4. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 4, afbeelding 1 van 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 7 mm screws around the gearbox using a Torx TR8 screwdriver.
    • Remove the gearbox cover.
    • Be careful about handling the wheel assembly with the gearbox exposed. Debris can enter in and the gears may fall out.
  5. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 5, afbeelding 1 van 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 5, afbeelding 2 van 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: stap 5, afbeelding 3 van 3
    • If holding the motor vertical, it may fall out once the screws are removed.
    • Using the Phillips #0 screwdriver, remove the two 4mm screws holding the motor to the gearbox.
    • Remove the motor.
Conclusie
Brycen Wirick
271 Reputatie
1 Handleiding geschreven
Utah Tech University, Team 1-3, McMurrin Fall 2023 Lid van Utah Tech University, Team 1-3, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G3
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 271
