Ga door naar hoofdinhoud
Sew a Ladder Stitch
Wat je nodig hebt
  1. Sew a Ladder Stitch, Sew a Ladder Stitch: stap 1, afbeelding 1 van 3 Sew a Ladder Stitch, Sew a Ladder Stitch: stap 1, afbeelding 2 van 3 Sew a Ladder Stitch, Sew a Ladder Stitch: stap 1, afbeelding 3 van 3
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Sew a Ladder Stitch: stap 2, afbeelding 1 van 2 Sew a Ladder Stitch: stap 2, afbeelding 2 van 2
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Sew a Ladder Stitch: stap 3, afbeelding 1 van 2 Sew a Ladder Stitch: stap 3, afbeelding 2 van 2
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Sew a Ladder Stitch: stap 4, afbeelding 1 van 2 Sew a Ladder Stitch: stap 4, afbeelding 2 van 2
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Sew a Ladder Stitch: stap 5, afbeelding 1 van 3 Sew a Ladder Stitch: stap 5, afbeelding 2 van 3 Sew a Ladder Stitch: stap 5, afbeelding 3 van 3
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
Eindstreep
Brittany McCrigler
89.017 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 79
Altijd: 9,827
