Inleiding
This repair guide solves any rotation and vibration problems that the fan might have. The track at the bottom of the fan is the main source of rotation and vibration problems. Use the tear-down guide to remove all other components to get to the track.
Wat je nodig hebt
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
In order to remove the fan blade, use pliers to remove the holding nut.
After the holding nut is loose, use the pliers to pull up to remove the nut.
Clean the track, removing any obstructions.
Lubricate the track with grease.
