Ga door naar hoofdinhoud
Seville Classics MSC10166 Buttons Replacement
Wat je nodig hebt
    1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): stap 1, afbeelding 1 van 1
      • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. Seville Classics MSC10166 Buttons Replacement: stap 2, afbeelding 1 van 1
      • Pull the front and back cover apart.
      • Be careful not to pull the front cover off completely. It holds the wires.
      Vraag FixBot
      Voeg opmerking toe
    3. Seville Classics MSC10166 Buttons Replacement: stap 3, afbeelding 1 van 1
      • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
      • Shock warning: Make sure the fan is unplugged before removing the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    4. Seville Classics MSC10166 Buttons Replacement: stap 4, afbeelding 1 van 1
      • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
      Vraag FixBot
      Voeg opmerking toe
    5. Seville Classics MSC10166 Buttons Replacement: stap 5, afbeelding 1 van 2 Seville Classics MSC10166 Buttons Replacement: stap 5, afbeelding 2 van 2
      • Remove the screws from the four corners of the circuit board.
      • Remove the circuit board from the top cover.
      • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
      Vraag FixBot
      Voeg opmerking toe
    1. Seville Classics MSC10166 Buttons Replacement, Buttons: stap 6, afbeelding 1 van 1
      • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
      Vraag FixBot
      Voeg opmerking toe
    2. Seville Classics MSC10166 Buttons Replacement: stap 7, afbeelding 1 van 1
      • Remove the buttons from the top cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Seville Classics MSC10166 Buttons Replacement: stap 8, afbeelding 1 van 1
      • Wipe down any dirt on the buttons.
      Vraag FixBot
      Voeg opmerking toe
    4. Seville Classics MSC10166 Buttons Replacement: stap 9, afbeelding 1 van 1
      • Wipe down the frame that holds the buttons.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Queena Phung
114 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-46, Forte Fall 2012 Lid van Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Leden
6 handleidingen geschreven
2Gids Commentaar
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Antwoord Deel
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 58
Altijd: 4,786
