Ga door naar hoofdinhoud
Service Panel Disassembly
Wat je nodig hebt
    1. Service Panel Disassembly, Remove Service Panel Screws: stap 1, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Anti-Static Wrist Strap
      $7.95
      • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
      • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
      Vraag FixBot
      Voeg opmerking toe
    2. Service Panel Disassembly, Dislodge Service Panel: stap 2, afbeelding 1 van 3 Service Panel Disassembly, Dislodge Service Panel: stap 2, afbeelding 2 van 3 Service Panel Disassembly, Dislodge Service Panel: stap 2, afbeelding 3 van 3
      • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
      • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
iodyne
462 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 440
