Ga door naar hoofdinhoud
Separating Main Board
Wat je nodig hebt
    1. Separating Main Board, Remove Battery: stap 1, afbeelding 1 van 3 Separating Main Board, Remove Battery: stap 1, afbeelding 2 van 3 Separating Main Board, Remove Battery: stap 1, afbeelding 3 van 3
      • Place the controller face down.
      • Remove the battery cover.
      • Remove rechargeable battery or AA batteries.
      Vraag FixBot
      Voeg opmerking toe
    2. Separating Main Board, Remove Trigger Buttons: stap 2, afbeelding 1 van 2 Separating Main Board, Remove Trigger Buttons: stap 2, afbeelding 2 van 2
      • Remove L2 and R2 trigger buttons by pushing them away from the grips.
      Vraag FixBot
      Voeg opmerking toe
    3. Separating Main Board, Remove Screws: stap 3, afbeelding 1 van 2 Separating Main Board, Remove Screws: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use Tweezers to uncover two screws under the label in the battery compartment.
      • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
      Vraag FixBot
      Voeg opmerking toe
    4. Separating Main Board, Unclip Covers: stap 4, afbeelding 1 van 3 Separating Main Board, Unclip Covers: stap 4, afbeelding 2 van 3 Separating Main Board, Unclip Covers: stap 4, afbeelding 3 van 3
      • At the end of each grip, pry apart the covers.
      • Use fingernail or opening pick to undo the two top clips.
      • One clip next to L button.
      • One clip next to R button
      • Undo the final clip between the joysticks.
      Vraag FixBot
      Voeg opmerking toe
    5. Separating Main Board, Separate Covers: stap 5, afbeelding 1 van 1
      • Carefully move the rear cover away and from the front cover. Place it to the left.
      • Do not completely separate. The two halves are still attached via a white ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    1. Separating Main Board, Remove Ribbon Cable: stap 6, afbeelding 1 van 3 Separating Main Board, Remove Ribbon Cable: stap 6, afbeelding 2 van 3 Separating Main Board, Remove Ribbon Cable: stap 6, afbeelding 3 van 3
      • Unlock the ribbon cable by push open the black plastic tab.
      • The tab will slide about 1.5mm
      • Pull the ribbon cable out of the connector in the direction of the cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Separating Main Board, Remove Screws: stap 7, afbeelding 1 van 3 Separating Main Board, Remove Screws: stap 7, afbeelding 2 van 3 Separating Main Board, Remove Screws: stap 7, afbeelding 3 van 3
      • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
      • Six 10.1mm screws
      • One 5.8mm screws
      Vraag FixBot
      Voeg opmerking toe
    3. Separating Main Board, Separate Main Board: stap 8, afbeelding 1 van 3 Separating Main Board, Separate Main Board: stap 8, afbeelding 2 van 3 Separating Main Board, Separate Main Board: stap 8, afbeelding 3 van 3
      • Slide the R buttons up and off its peg.
      • Slide the L button up and off its peg.
      • Remove the main board by rotating it towards the USB-C port. Then lift it out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brian W
1.800 Reputatie
8 handleidingen geschreven
1Gids Commentaar
if you need a replacement ribbon the specs are
length: 70mm
pitch: 0.5mm
pins: 20
forward side pinning (that means the contacts are on the same side)
some listings add the total width, thats 20.5mm
Max R. - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 1,207
