Ga door naar hoofdinhoud
Sega Dreamcast Fan Replacement
Wat je nodig hebt
  1. Sega Dreamcast Fan Replacement, Expansion Bay: stap 1, afbeelding 1 van 2 Sega Dreamcast Fan Replacement, Expansion Bay: stap 1, afbeelding 2 van 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
    Vraag FixBot
  2. Sega Dreamcast Fan Replacement: stap 2, afbeelding 1 van 3 Sega Dreamcast Fan Replacement: stap 2, afbeelding 2 van 3 Sega Dreamcast Fan Replacement: stap 2, afbeelding 3 van 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
    Vraag FixBot
  3. Sega Dreamcast Fan Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
    Vraag FixBot
  4. Sega Dreamcast Fan Replacement: stap 4, afbeelding 1 van 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
    Vraag FixBot
  5. Sega Dreamcast Fan Replacement, Fan: stap 5, afbeelding 1 van 1
    • Remove the white fan header by gently pulling it away from from the controller port.
    • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
    Vraag FixBot
  6. Sega Dreamcast Fan Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 8.5mm Philips #00 screws from the fan bracket.
    Vraag FixBot
  7. Sega Dreamcast Fan Replacement: stap 7, afbeelding 1 van 2 Sega Dreamcast Fan Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 17.5mm Philips #00 screws from the fan bracket.
    • Remove the fan from the bracket.
    Vraag FixBot
  8. Sega Dreamcast Fan Replacement, Fan: stap 8, afbeelding 1 van 2 Sega Dreamcast Fan Replacement, Fan: stap 8, afbeelding 2 van 2
    • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
    • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
    Vraag FixBot
Conclusie
6 andere personen hebben deze handleiding voltooid.
Thorr686
528 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-1, Regan Fall 2009 Lid van Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 125
Altijd: 20,415
