Ga door naar hoofdinhoud
Sega Dreamcast Top Cover Replacement
Wat je nodig hebt
  1. Sega Dreamcast Top Cover Replacement, Expansion Bay: stap 1, afbeelding 1 van 2 Sega Dreamcast Top Cover Replacement, Expansion Bay: stap 1, afbeelding 2 van 2
    • Verify that the console is disconnected from the AC outlet before you begin.
    • Flip the console over on its back.
    • Take note of your model number, in case replacement parts are needed.
  2. Sega Dreamcast Top Cover Replacement: stap 2, afbeelding 1 van 3 Sega Dreamcast Top Cover Replacement: stap 2, afbeelding 2 van 3 Sega Dreamcast Top Cover Replacement: stap 2, afbeelding 3 van 3
    • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  3. Sega Dreamcast Top Cover Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
    • Note: Remove the expansion bay to locate the fourth screw
  4. Sega Dreamcast Top Cover Replacement: stap 4, afbeelding 1 van 1
    • Internal components can be loose. Be careful that they do not fall out when removing the cover.
    • Turn the console right side up.
    • Remove the top cover by gently lifting the upper portion of the console.
Conclusie
6 andere personen hebben deze handleiding voltooid.
wkwong
529 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-1, Regan Fall 2009 Lid van Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 74
Altijd: 11,870
