Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Before attempting this guide complete the CD Tray Removal Guide.
Onderdelen
Geen onderdelen opgegeven.
  1. Using a Phillips head screwdriver remove  six screws from the bottom of the console. The six screws are marked.
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Remove the two screws that attach the Genesis' connector to the rest of the console.
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Slide the lock tab to the left to separate the halves of the console.
    • Slide the lock tab to the left to separate the halves of the console.
  4. Lift from the left side to remove the top of the case.
    • Lift from the left side to remove the top of the case.
  5. Using the spudger, pry the cover off of the Genesis attachment.
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Lift the top of the case to remove the cover.
    • Lift the top of the case to remove the cover.
  7. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  8. Remove the faceplate by pulling it up, then out.
    • Remove the faceplate by pulling it up, then out.
  9. Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate. The three screws are shown on the diagram.
    • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
    • The three screws are shown on the diagram.
  10. Remove the two screws from the plastic bar. The two screws are shown pictured.
    • Remove the two screws from the plastic bar.
    • The two screws are shown pictured.
  11. To remove the CD tray Remove the four screws with the Phillips head screwdriver.
    • To remove the CD tray
    • Remove the four screws with the Phillips head screwdriver.
  12. Carefully unplug the wire connected to optical reader.
    • Carefully unplug the wire connected to optical reader.
  13. Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver. The four screws are highlighted on the diagram.
    • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
    • The four screws are highlighted on the diagram.
    • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
  14. Carefully remove the CD tray from circuit board.
    • Carefully remove the CD tray from circuit board.
  15. Remove the two bronze screws from the metal plate with a medium Phillips head screwdriver. The screws are marked on the diagram. Carefully lift the metal plate up to expose the motherboard.
    • Remove the two bronze screws from the metal plate with a medium Phillips head screwdriver.
    • The screws are marked on the diagram.
    • Carefully lift the metal plate up to expose the motherboard.
    • There is a wire strip running through the metal plate that is soldered to motherboard and power supply board. The plate cannot be completely removed. Do NOT force plate upwards. All the ribbon cables can be safely unplugged by simply pulling them out of their slots.
  16. Carefully lift off the metal plate, the motherboard, and the CD tray circuit board. Then,  flip each piece over, as pictured. Carefully lift off the metal plate, the motherboard, and the CD tray circuit board. Then,  flip each piece over, as pictured.
    • Carefully lift off the metal plate, the motherboard, and the CD tray circuit board. Then, flip each piece over, as pictured.
  17. Remove the two screws from the power supply using a medium Phillips head screwdriver. The two screws are marked on the diagram. The two screws are marked on the diagram.
    • Remove the two screws from the power supply using a medium Phillips head screwdriver.
    • The two screws are marked on the diagram.
  18. Remove the power supply unit from the console by lifting the unit up.
    • Remove the power supply unit from the console by lifting the unit up.
  19. This is what the motherboard unit will look like once removed.
    • This is what the motherboard unit will look like once removed.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ryan Kotzebue
259 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-14, Maness Fall 2010 Lid van Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Leden
12 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 8,828
