Inleiding
Use this guide to replace or remove the thumbsticks on your Scuf Reflex controller.
Wat je nodig hebt
At the bottom tip of the right grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
Pry up to release the faceplate trim’s bottom right clip.
At the bottom tip of the left grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
Pry up to release the faceplate trim’s bottom left clip.
Insert the flat end of a spudger between the faceplate trim and the back cover, next to the headphone jack.
Pry up to release the plastic clips securing the center of the faceplate trim.
Lift the bottom edge of the faceplate trim and thread it up and over the thumbsticks.
Pull the top corners of the faceplate trim out from underneath the faceplate and remove the faceplate trim.
Pull the thumbsticks straight up and off of their joysticks to remove them.
To reassemble your device, follow the instructions in reverse order.
6 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Actually, the base of the thumbsticks is bigger and you can't pull it up. I really don't know if the new models are different.
I had to release the entire top cover.
