Ga door naar hoofdinhoud
Sanyo VPC S1275 LCD Screen Replacement
Wat je nodig hebt
    1. Sanyo VPC S1275 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
      • Place your thumb on the right side of the camera over the battery door.
      • Slide the battery door to the right until the door lifts up.
      Vraag FixBot
      Voeg opmerking toe
    2. Sanyo VPC S1275 LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove and recycle old batteries.
      Vraag FixBot
      Voeg opmerking toe
    1. Sanyo VPC S1275 LCD Screen Replacement, Case: stap 3, afbeelding 1 van 3 Sanyo VPC S1275 LCD Screen Replacement, Case: stap 3, afbeelding 2 van 3 Sanyo VPC S1275 LCD Screen Replacement, Case: stap 3, afbeelding 3 van 3
      • Remove the following six screws using the Phillips #00 screwdriver:
      • Two screws on the left side of the camera.
      • Two screws on the right side of the camera.
      • Two screws on the bottom of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Sanyo VPC S1275 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Sanyo VPC S1275 LCD Screen Replacement: stap 4, afbeelding 2 van 2
      • Open the battery slot on the bottom of the camera by sliding the door to the right.
      • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Sanyo VPC S1275 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Sanyo VPC S1275 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Sanyo VPC S1275 LCD Screen Replacement: stap 5, afbeelding 3 van 3
      • Insert a spudger in the seam at the bottom of the camera.
      • Gently separate the rear case from the front of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Sanyo VPC S1275 LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • This step is only needed for the case and logic board replacement
      • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
      Vraag FixBot
      Voeg opmerking toe
    5. Sanyo VPC S1275 LCD Screen Replacement: stap 7, afbeelding 1 van 1
      • This step is only needed for the case replacement.
      • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
      • Slide the battery door off of the hinge.
      Vraag FixBot
      Voeg opmerking toe
    1. Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 2 Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 2 van 2
      • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
      • Place the LCD screen on a non-abrasive surface.
      Vraag FixBot
      Voeg opmerking toe
    2. Sanyo VPC S1275 LCD Screen Replacement: stap 9, afbeelding 1 van 1
      • Using the spudger lift the black flap up to release the ribbon cable.
      • The LCD screen will now be completely detached from the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Evan Perez
19 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-24, Regan Spring 2010 Lid van Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Leden
30 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 51
Altijd: 3,697
