Ga door naar hoofdinhoud
Sansa e260R Memory Board Replacement
Wat je nodig hebt
    1. Sansa e260R Memory Board Replacement, Rear Case: stap 1, afbeelding 1 van 1
      • Before disassembling the device, make sure it is powered off.
      • Remove the four 1.5mm screws on the back of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Sansa e260R Memory Board Replacement: stap 2, afbeelding 1 van 1
      • Using a plastic opening tool, lift the metal backing from the front of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Sansa e260R Memory Board Replacement: stap 3, afbeelding 1 van 1
      • Pull the rear panel off of the Sansa e260R.
      Vraag FixBot
      Voeg opmerking toe
    1. Sansa e260R Memory Board Replacement, Battery: stap 4, afbeelding 1 van 1
      • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Sansa e260R Memory Board Replacement, Front Panel: stap 5, afbeelding 1 van 1
      • Remove the four 1.5mm screws on the inner casing of the device.
      • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Sansa e260R Memory Board Replacement: stap 6, afbeelding 1 van 1
      • Flip the device so that the front is facing you.
      • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Sansa e260R Memory Board Replacement: stap 7, afbeelding 1 van 2 Sansa e260R Memory Board Replacement: stap 7, afbeelding 2 van 2
      • Pull the front cover away from the rest of the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Sansa e260R Memory Board Replacement, Memory Board: stap 8, afbeelding 1 van 2 Sansa e260R Memory Board Replacement, Memory Board: stap 8, afbeelding 2 van 2
      • Near the charging port, pull the case away from the motherboard to create clearance to remove the motherboard.
      • Use the spudger to push the motherboard in and pop the metal edge of the charging port up and inside the plastic case.
      Vraag FixBot
      Voeg opmerking toe
    2. Sansa e260R Memory Board Replacement: stap 9, afbeelding 1 van 1
      • Pull the bottom of the motherboard up and then out.
      Vraag FixBot
      Voeg opmerking toe
    3. Sansa e260R Memory Board Replacement: stap 10, afbeelding 1 van 1
      • On the back of the motherboard, there is a rectangle of rubber.
      • Peel the rectangle off slowly.
      Vraag FixBot
      Voeg opmerking toe
    4. Sansa e260R Memory Board Replacement: stap 11, afbeelding 1 van 1
      • Under the rubber rectangle, there is a strip of black tape.
      • Peel the tape off about halfway so that it is no longer attached to the memory board.
      Vraag FixBot
      Voeg opmerking toe
    5. Sansa e260R Memory Board Replacement: stap 12, afbeelding 1 van 1
      • Carefully peel the memory board away from the rest of the motherboard
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
JenniferW
194 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-15, Maness Winter 2012 Lid van Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Leden
20 handleidingen geschreven
1Gids Commentaar
thanks a million for this. i accidentally erased the boot partition, bought another one on eBay with a defective audio channel and switched the memory board: eureka! i’m happy listening to my tunes again!
Admin User - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 3,118
