Ga door naar hoofdinhoud
Samsung WB850F Lens Assembly Replacement
Wat je nodig hebt
    1. Samsung WB850F Lens Assembly  Replacement, Control Panel: stap 1, afbeelding 1 van 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: stap 1, afbeelding 2 van 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: stap 1, afbeelding 3 van 3
      • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
      • 2 screws are located on the bottom.
      • 2 screws are located on the left side. (HDMI port)
      • 2 screws are located on the right side of the camera. (Opposite HDMI side)
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB850F Lens Assembly  Replacement: stap 2, afbeelding 1 van 1
      • To remove the back screen case, use the blue opening tool to open the case up from the right side.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung WB850F Lens Assembly  Replacement: stap 3, afbeelding 1 van 2 Samsung WB850F Lens Assembly  Replacement: stap 3, afbeelding 2 van 2
      • Use screwdriver to remove control panel screw.
      • Lift up control panel from the side where the screw was just removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: stap 4, afbeelding 1 van 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: stap 4, afbeelding 2 van 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: stap 4, afbeelding 3 van 3
      • Remove the two screws.
      • Gently pry open metal case using Plastic tool openers.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB850F Lens Assembly  Replacement: stap 5, afbeelding 1 van 2 Samsung WB850F Lens Assembly  Replacement: stap 5, afbeelding 2 van 2
      • Gently pull up on the lens connector chip to remove the lens.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung WB850F Lens Assembly  Replacement: stap 6, afbeelding 1 van 1
      • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jousling Vazquez
431 Reputatie
4 handleidingen geschreven
USF Tampa, Team 12-4, Eyestone Spring 2016 Lid van USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Leden
8 handleidingen geschreven
2Gids Commentaar
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - Antwoord Deel
I am forward to hearing from you....
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 2,005
