Ga door naar hoofdinhoud
Samsung UBD-KM85C Disc Drive Replacement
Wat je nodig hebt
  1. Samsung UBD-KM85C Disc Drive Replacement, Outer Shell: stap 1, afbeelding 1 van 1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung UBD-KM85C Disc Drive Replacement: stap 2, afbeelding 1 van 2 Samsung UBD-KM85C Disc Drive Replacement: stap 2, afbeelding 2 van 2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung UBD-KM85C Disc Drive Replacement: stap 3, afbeelding 1 van 3 Samsung UBD-KM85C Disc Drive Replacement: stap 3, afbeelding 2 van 3 Samsung UBD-KM85C Disc Drive Replacement: stap 3, afbeelding 3 van 3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung UBD-KM85C Disc Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the cover from the device.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung UBD-KM85C Disc Drive Replacement, Disc Drive: stap 5, afbeelding 1 van 1
    • The disk drive is the large metallic rectangular unit that occupies a third of the space inside the unit.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung UBD-KM85C Disc Drive Replacement: stap 6, afbeelding 1 van 2 Samsung UBD-KM85C Disc Drive Replacement: stap 6, afbeelding 2 van 2
    • The disk drive has four 6.5mm screws located near each of its corners that hold it onto the frame. Use a #1 Phillips head screwdriver to remove these screws.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung UBD-KM85C Disc Drive Replacement: stap 7, afbeelding 1 van 3 Samsung UBD-KM85C Disc Drive Replacement: stap 7, afbeelding 2 van 3 Samsung UBD-KM85C Disc Drive Replacement: stap 7, afbeelding 3 van 3
    • The disk drive has two connections to the motherboard that can be disconnected by pulling on the blue plastic tabs.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung UBD-KM85C Disc Drive Replacement: stap 8, afbeelding 1 van 1
    • Once the connections are unplugged and the screws are removed, the disk drive can be lifted out. The previous steps can be done in the reverse order to replace the part.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
James Edwards
627 Reputatie
5 handleidingen geschreven
Baylor, Team S2-G1, Johnson Spring 2018 Lid van Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 Leden
6 handleidingen geschreven
1Gids Commentaar
How do I eject a disk that's stuck in the drive?
Martin Y - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 696
