Ga door naar hoofdinhoud
Samsung Series 5 Ultrabook RAM Replacement
Wat je nodig hebt
  1. Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: stap 1, afbeelding 1 van 2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Screws on the Back Cover: stap 1, afbeelding 2 van 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: stap 2, afbeelding 1 van 2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Rubber Pads: stap 2, afbeelding 2 van 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: stap 3, afbeelding 1 van 2 Samsung Series 5 Ultrabook RAM Replacement, Remove the Back Cover: stap 3, afbeelding 2 van 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 Ultrabook RAM Replacement: stap 4, afbeelding 1 van 2 Samsung Series 5 Ultrabook RAM Replacement: stap 4, afbeelding 2 van 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 Ultrabook RAM Replacement: stap 5, afbeelding 1 van 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 Ultrabook RAM Replacement, Remove the Battery: stap 6, afbeelding 1 van 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 Ultrabook RAM Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery from the laptop.
  8. Samsung Series 5 Ultrabook RAM Replacement, RAM: stap 8, afbeelding 1 van 3 Samsung Series 5 Ultrabook RAM Replacement, RAM: stap 8, afbeelding 2 van 3 Samsung Series 5 Ultrabook RAM Replacement, RAM: stap 8, afbeelding 3 van 3
    • Use a spudger (or your fingers) to unhinge the left and right clips holding the RAM in place.
  9. Samsung Series 5 Ultrabook RAM Replacement: stap 9, afbeelding 1 van 1
    • Carefully remove the RAM when both tabs have been fully disengaged.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Javier Jimenez
223 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G6, Harley Fall 2019 Lid van IUPUI, Team S1-G6, Harley Fall 2019
IUPUI-HARLEY-F19S1G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 1,514
