Inleiding
This guide will show how to remove the covers from the underside of the laptop, remove the battery, and replace it with the new battery.
Wat je nodig hebt
Power off the device. Remove the remaining screws holding the back cover in place:
Six 4.0 mm Phillips #00 screws.
Seven 6.7 mm Phillips #00 screws.
Remove the two rubber pads concealing the final bottom case screws.
Remove the two 4 mm Phillips #00 screws found under these pads.
There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
Remove the entire rest of the back cover.
14 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
If you have a computer connected to a power supply that will still allow it to work.
