Ga door naar hoofdinhoud
Samsung SPEX SCH-R210 antenna Replacement
Wat je nodig hebt
  1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: stap 1, afbeelding 1 van 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: stap 1, afbeelding 2 van 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung SPEX SCH-R210 antenna Replacement, Battery: stap 2, afbeelding 1 van 1
    • Locate the access notch at the end of the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung SPEX SCH-R210 antenna Replacement: stap 3, afbeelding 1 van 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung SPEX SCH-R210 antenna Replacement, Antenna: stap 4, afbeelding 1 van 2 Samsung SPEX SCH-R210 antenna Replacement, Antenna: stap 4, afbeelding 2 van 2
    • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung SPEX SCH-R210 antenna Replacement: stap 5, afbeelding 1 van 2 Samsung SPEX SCH-R210 antenna Replacement: stap 5, afbeelding 2 van 2
    • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung SPEX SCH-R210 antenna Replacement: stap 6, afbeelding 1 van 1
    • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung SPEX SCH-R210 antenna Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung SPEX SCH-R210 antenna Replacement: stap 8, afbeelding 1 van 1
    • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung SPEX SCH-R210 antenna Replacement: stap 9, afbeelding 1 van 1
    • Replace with a new antenna.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Susan
331 Reputatie
3 handleidingen geschreven
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Lid van WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 550
