Ga door naar hoofdinhoud
Samsung SPEX SCH-R210 Keypad Replacement
Wat je nodig hebt
  1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: stap 1, afbeelding 1 van 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: stap 1, afbeelding 2 van 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung SPEX SCH-R210 Keypad Replacement, Battery: stap 2, afbeelding 1 van 1
    • Locate the access notch at the end of the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung SPEX SCH-R210 Keypad Replacement: stap 3, afbeelding 1 van 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: stap 4, afbeelding 1 van 2 Samsung SPEX SCH-R210 Keypad Replacement, Keypad: stap 4, afbeelding 2 van 2
    • Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung SPEX SCH-R210 Keypad Replacement: stap 5, afbeelding 1 van 1
    • Remove the headphone cover from the left side of the midframe.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung SPEX SCH-R210 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Remove the volume cover from the right side of the midframe.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung SPEX SCH-R210 Keypad Replacement: stap 7, afbeelding 1 van 1
    • Use your hands to separate the midframe from the rest of the phone.
    • This may take a little effort to remove.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung SPEX SCH-R210 Keypad Replacement: stap 8, afbeelding 1 van 1
    • Use a 1.5 mm hex screwdriver to remove the three 2.4 mm screws around the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung SPEX SCH-R210 Keypad Replacement: stap 9, afbeelding 1 van 1
    • Lift the metal plate off of the motherboard and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung SPEX SCH-R210 Keypad Replacement: stap 10, afbeelding 1 van 2 Samsung SPEX SCH-R210 Keypad Replacement: stap 10, afbeelding 2 van 2
    • Push on the white plastic tabs and the keypad at the same time to remove the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung SPEX SCH-R210 Keypad Replacement: stap 11, afbeelding 1 van 2 Samsung SPEX SCH-R210 Keypad Replacement: stap 11, afbeelding 2 van 2
    • Turn the phone over to its front side.
    • Apply pressure on the keypad.
    • The keypad will come out easily.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Susan
331 Reputatie
3 handleidingen geschreven
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Lid van WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 646
