Ga door naar hoofdinhoud
Samsung Rogue Keyboard Replacement
Wat je nodig hebt
    1. Samsung Rogue Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Rogue Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
      • Before disassembling your Samsung Rogue, make sure it is powered off.
      • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Rogue Keyboard Replacement: stap 2, afbeelding 1 van 2 Samsung Rogue Keyboard Replacement: stap 2, afbeelding 2 van 2
      • You can now remove the battery by prying it up with your finger.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Rogue Keyboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
      • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Rogue Keyboard Replacement: stap 4, afbeelding 1 van 1
      • Remove the five 3.4mm Philips screws securing the backing of the phone.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Rogue Keyboard Replacement: stap 5, afbeelding 1 van 3 Samsung Rogue Keyboard Replacement: stap 5, afbeelding 2 van 3 Samsung Rogue Keyboard Replacement: stap 5, afbeelding 3 van 3
      • Use a plastic opening tool to carefully pry off the back cover.
      • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
      • Be careful to not drop the volume changing piece, for it can easily slip out.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Rogue Keyboard Replacement: stap 6, afbeelding 1 van 1
      • Remove the two 3.45 mm Philips screws below the white sticker.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Rogue Keyboard Replacement: stap 7, afbeelding 1 van 2 Samsung Rogue Keyboard Replacement: stap 7, afbeelding 2 van 2
      • Carefully lift the motherboard up from the bottom edge.
      • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
      Vraag FixBot
      Voeg opmerking toe
    6. Samsung Rogue Keyboard Replacement: stap 8, afbeelding 1 van 2 Samsung Rogue Keyboard Replacement: stap 8, afbeelding 2 van 2
      • Use a plastic opening tool to disconnect the film from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Rogue Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 1
      • Remove the eight 1.7mm Philips screws above the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Rogue Keyboard Replacement: stap 10, afbeelding 1 van 1
      • Carefully remove keyboard holder from the slider mechanisms underneath.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Rogue Keyboard Replacement: stap 11, afbeelding 1 van 2 Samsung Rogue Keyboard Replacement: stap 11, afbeelding 2 van 2
      • Turn keyboard holder over and allow the keyboard to simply fall out into your hand.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Viktoria Mikoultchik
25 Reputatie
7 handleidingen geschreven
Cal Poly, Team 7-32, Maness Spring 2012 Lid van Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Leden
36 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 28
Altijd: 610
