Ga door naar hoofdinhoud
Samsung Refrigerator Evaporator Drain Clip Replacement
Wat je nodig hebt
  1. Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: stap 1, afbeelding 1 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: stap 1, afbeelding 2 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement, Evaporator Drain Clip: stap 1, afbeelding 3 van 3
    • Using a spudger, pry off the cap covering the topmost screw.
  2. Samsung Refrigerator Evaporator Drain Clip Replacement: stap 2, afbeelding 1 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 2, afbeelding 2 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 2, afbeelding 3 van 3
    • Remove three 12.7 mm screws using a Phillips #0 screwdriver.
  3. Samsung Refrigerator Evaporator Drain Clip Replacement: stap 3, afbeelding 1 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 3, afbeelding 2 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 3, afbeelding 3 van 3
    • Use your hands or a spudger to pry back the plastic cover starting from the bottom.
    • Once all the clips are pulled out, loosen the cover by pushing it slightly up and out.
    • Do not pull the cover off yet; there are still connectors attaching the cover to the fridge.
  4. Samsung Refrigerator Evaporator Drain Clip Replacement: stap 4, afbeelding 1 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 4, afbeelding 2 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 4, afbeelding 3 van 3
    • Gently unplug both connectors.
    • Remember their orientations as it will be important during reassembly.
  5. Samsung Refrigerator Evaporator Drain Clip Replacement: stap 5, afbeelding 1 van 1
    • Using a hair dryer or heat gun, melt down any ice buildup in the draining well.
  6. Samsung Refrigerator Evaporator Drain Clip Replacement: stap 6, afbeelding 1 van 1
    • Cut out the old evaporating clip using a pair of cutting pliers.
  7. Samsung Refrigerator Evaporator Drain Clip Replacement: stap 7, afbeelding 1 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 7, afbeelding 2 van 3 Samsung Refrigerator Evaporator Drain Clip Replacement: stap 7, afbeelding 3 van 3
    • Replace the old clip with a new evaporating clip.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Deep Patel
299 Reputatie
1 Handleiding geschreven
3 opmerkingen
Problem only resolved for about 6 months post clip replacement. Now every 2 months back to defrosting my refrigerator, under the crisper drawer. Now the entire section of the drain is frozen. Very frustraing.
David Kahan - Antwoord
Here's another video of this replacement. Head over to the refrigerator leaking water wiki for more fixes for freezing lines.
nicO - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 65
Afgelopen 30 dagen: 327
Altijd: 15,414
