Ga door naar hoofdinhoud
Samsung Refrigerator Door Sensors Replacement
Wat je nodig hebt
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: stap 1, afbeelding 1 van 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: stap 2, afbeelding 1 van 1
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: stap 3, afbeelding 1 van 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: stap 4, afbeelding 1 van 2 Samsung Refrigerator Door Sensors Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: stap 5, afbeelding 1 van 1
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: stap 6, afbeelding 1 van 2 Samsung Refrigerator Door Sensors Replacement, Sensor information: stap 6, afbeelding 2 van 2
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: stap 7, afbeelding 1 van 2 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: stap 7, afbeelding 2 van 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: stap 8, afbeelding 1 van 2 Samsung Refrigerator Door Sensors Replacement: stap 8, afbeelding 2 van 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: stap 9, afbeelding 1 van 1
    • Remove the door sensor.
Conclusie
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
15.927 Reputatie
88 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
35 Leden
603 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 311
Altijd: 3,465
