Inleiding
This guide shows how to remove and replace the icemaker assembly in your Samsung RF28R7201SG refrigerator.
The icemaker assembly is a combination of parts that creates ice. It's prone to a variety of malfunctions, such as not defrosting properly or not making ice. Some of these issues can be resolved by replacing the icemaker assembly.
Wat je nodig hebt
Open both French doors for the refrigerator compartment.
Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
Remove the cable cover panel.
Disconnect the left-most yellow connector:
Squeeze the locking tab with the red mark with your fingers
Rock the connector gently side to side to disconnect it
Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
A plastic clip holds the air tunnel flap in place.
Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
Repair didn’t go as planned? Ask our Answers community for help.
