Ga door naar hoofdinhoud
Samsung PL20 LCD Replacement
Wat je nodig hebt
  1. Samsung PL20 LCD Replacement, LCD: stap 1, afbeelding 1 van 3 Samsung PL20 LCD Replacement, LCD: stap 1, afbeelding 2 van 3 Samsung PL20 LCD Replacement, LCD: stap 1, afbeelding 3 van 3
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. Samsung PL20 LCD Replacement: stap 2, afbeelding 1 van 3 Samsung PL20 LCD Replacement: stap 2, afbeelding 2 van 3 Samsung PL20 LCD Replacement: stap 2, afbeelding 3 van 3
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  3. Samsung PL20 LCD Replacement: stap 3, afbeelding 1 van 3 Samsung PL20 LCD Replacement: stap 3, afbeelding 2 van 3 Samsung PL20 LCD Replacement: stap 3, afbeelding 3 van 3
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
Conclusie
7 andere personen hebben deze handleiding voltooid.
oldturkey03
844.906 Reputatie
123 handleidingen geschreven
1Gids Commentaar
Great help! Screen replaced no problem. Thank you
EE61 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 62
Altijd: 4,216
