Ga door naar hoofdinhoud
Samsung NX500 Image Sensor Replacement
Wat je nodig hebt
    1. Samsung NX500 Image Sensor Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung NX500 Image Sensor Replacement, Battery: stap 1, afbeelding 2 van 2
      • Pull the switch on the bottom of the camera back with your thumb.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung NX500 Image Sensor Replacement: stap 2, afbeelding 1 van 2 Samsung NX500 Image Sensor Replacement: stap 2, afbeelding 2 van 2
      • Push second switch(blue) forward with your thumb.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung NX500 Image Sensor Replacement: stap 3, afbeelding 1 van 1
      • Pull out battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung NX500 Image Sensor Replacement, Screen Side Encasement: stap 4, afbeelding 1 van 3 Samsung NX500 Image Sensor Replacement, Screen Side Encasement: stap 4, afbeelding 2 van 3 Samsung NX500 Image Sensor Replacement, Screen Side Encasement: stap 4, afbeelding 3 van 3
      • Open the screen exposing the hinge cover and place the plastic opening tool inside.
      • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
      • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung NX500 Image Sensor Replacement: stap 5, afbeelding 1 van 3 Samsung NX500 Image Sensor Replacement: stap 5, afbeelding 2 van 3 Samsung NX500 Image Sensor Replacement: stap 5, afbeelding 3 van 3
      • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
      • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
      • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
      • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung NX500 Image Sensor Replacement: stap 6, afbeelding 1 van 2 Samsung NX500 Image Sensor Replacement: stap 6, afbeelding 2 van 2
      • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
      • The casing should be removed easily; you shouldn't have to use much force.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung NX500 Image Sensor Replacement: stap 7, afbeelding 1 van 2 Samsung NX500 Image Sensor Replacement: stap 7, afbeelding 2 van 2
      • Locate the black ribbon at the bottom left of the camera's interior.
      • Place the plastic opening tool under the black ribbon connector.
      • Remove the cable by moving your plastic opening tool in a downward motion.
      • There is zero to little force needed to remove this ribbon.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung NX500 Image Sensor Replacement, Main board: stap 8, afbeelding 1 van 3 Samsung NX500 Image Sensor Replacement, Main board: stap 8, afbeelding 2 van 3 Samsung NX500 Image Sensor Replacement, Main board: stap 8, afbeelding 3 van 3
      • Lift the black latch of the left main ribbon connector using a wide-set plastic opening tool in a downward motion.
      • Use your fingers to disconnect the cable.
      • There are five ZIF cables total to be removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung NX500 Image Sensor Replacement: stap 9, afbeelding 1 van 3 Samsung NX500 Image Sensor Replacement: stap 9, afbeelding 2 van 3 Samsung NX500 Image Sensor Replacement: stap 9, afbeelding 3 van 3
      • Use the wide-set plastic opening tool to lift the latch on the right main ZIF cable in a downward motion.
      • Disconnect the cable using your finger.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung NX500 Image Sensor Replacement: stap 10, afbeelding 1 van 2 Samsung NX500 Image Sensor Replacement: stap 10, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Locate the ZIF cable at the bottom of the main board.
      • Disconnect the cable with the tweezers by pulling it away from where the cable is connected.
      • Be careful not tug too hard on the cable as you can damage it.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung NX500 Image Sensor Replacement: stap 11, afbeelding 1 van 2 Samsung NX500 Image Sensor Replacement: stap 11, afbeelding 2 van 2
      • Locate the skinny ZIF cable on the left side of the main board.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung NX500 Image Sensor Replacement: stap 12, afbeelding 1 van 3 Samsung NX500 Image Sensor Replacement: stap 12, afbeelding 2 van 3 Samsung NX500 Image Sensor Replacement: stap 12, afbeelding 3 van 3
      • Locate the black cable connected at the top right of the main board.
      • Place the wide-set plastic opening tool underneath the gray connector and carefully pry it up.
      • It will easily pop up.
      Vraag FixBot
      Voeg opmerking toe
    6. Samsung NX500 Image Sensor Replacement: stap 13, afbeelding 1 van 1
      • Remove the 4 black 4-mm Phillips #000 screws located near each corner of the main board.
      • Lift the board out of the casing and carefully put it somewhere safe.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung NX500 Image Sensor Replacement, Image Sensor: stap 14, afbeelding 1 van 2 Samsung NX500 Image Sensor Replacement, Image Sensor: stap 14, afbeelding 2 van 2
      • Remove the three black 5-mm T6 type screws using a Torx screwdriver located along the metal casing of the image sensor.
      • The image sensor is very sensitive, be sure not to smudge the filter covering.
      • Pull the image sensor out and it can now be replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Eli Carcalete
599 Reputatie
4 handleidingen geschreven
USF Tampa, Team 18-5, Blackwell Fall 2016 Lid van USF Tampa, Team 18-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G5
3 Leden
12 handleidingen geschreven
3Gids Commentaar
Thanks for this, very helpfull.
I needed to replace the shutter assembly.
For this, next step is to remove the metal top of the camera (a screw on each side and 2 screws in the flash shoe below the spring).
After this the 2 screws on top of the shutter assembly can be removed.
The shutter assy can now be removed although it is somewhat easier if the tripod mount is removed first.
Piet van der Plas - Antwoord Deel
Very helpful. Thanks for posting.
My mode selector is not changing mode as it should, it seems like a contact failure. What shoul I do?
Juan Prekop
prekop - Antwoord Deel
thanks so much for sharing Well appreciated
dave_tjeng - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 2,528
