Inleiding
Replacing the flash on the Samsung NX30 is a bit of a challenge. It requires soldering. Make sure when you are performing this replacement to not touch the metal leads on either side of the flash bulb because they will shock you.
Wat je nodig hebt
Flip the camera over so that the bottom of the camera is up.
Push the battery switch towards the back of the camera.
If you are looking at the front of the camera with the lens facing you, look at the right side of the camera, press the flash button to pop up the flash head.
