Inleiding
Ga naar stap 1 ↓If your home and play buttons are not working on your Samsung NX2000, we are here to show you step-by-step how you can replace them yourself. It will connect with the previous LCD display replacement guide and show you the correct way to remove this button.
Wat je nodig hebt
Gereedschap
Spudger4.9
First begin by flipping your camera upside down.
Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
Detach the two ribbon cables, by first lifting the black tab on top of the connector.
Pull the ribbon cables out of the connectors with tweezers or two fingers.
Use the tweezers to pull out the home and playback buttons from the camera frame.
Één andere persoon heeft deze handleiding voltooid.
