Ga door naar hoofdinhoud
Samsung NP-QX411L Screen Replacement
Wat je nodig hebt
  1. Samsung NP-QX411L Screen Replacement, Optical Drive: stap 1, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement, Optical Drive: stap 1, afbeelding 2 van 2
    • Flip the laptop over.
    • Remove the 6 mm screw with the Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung NP-QX411L Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide out the optical drive to remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung NP-QX411L Screen Replacement, Hard Drive: stap 3, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement, Hard Drive: stap 3, afbeelding 2 van 2
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung NP-QX411L Screen Replacement: stap 4, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement: stap 4, afbeelding 2 van 2
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung NP-QX411L Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung NP-QX411L Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung NP-QX411L Screen Replacement, Hinges: stap 7, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement, Hinges: stap 7, afbeelding 2 van 2
    • Disconnect the wire from the motherboard by pulling up and away from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung NP-QX411L Screen Replacement: stap 8, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove the top two rubber stoppers using precision tweezers.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung NP-QX411L Screen Replacement: stap 9, afbeelding 1 van 1
    • Unscrew nine 6 mm screws on the cover using a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung NP-QX411L Screen Replacement: stap 10, afbeelding 1 van 3 Samsung NP-QX411L Screen Replacement: stap 10, afbeelding 2 van 3 Samsung NP-QX411L Screen Replacement: stap 10, afbeelding 3 van 3
    • Wedge the spudger under the cover to gently pry it up.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung NP-QX411L Screen Replacement: stap 11, afbeelding 1 van 3 Samsung NP-QX411L Screen Replacement: stap 11, afbeelding 2 van 3 Samsung NP-QX411L Screen Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the wire by carefully using the plastic opening tool to pry the connector away from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung NP-QX411L Screen Replacement: stap 12, afbeelding 1 van 3 Samsung NP-QX411L Screen Replacement: stap 12, afbeelding 2 van 3 Samsung NP-QX411L Screen Replacement: stap 12, afbeelding 3 van 3
    • Use precision tweezers to pop the antenna wires off of the WiFi card.
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung NP-QX411L Screen Replacement: stap 13, afbeelding 1 van 3 Samsung NP-QX411L Screen Replacement: stap 13, afbeelding 2 van 3 Samsung NP-QX411L Screen Replacement: stap 13, afbeelding 3 van 3
    • Open the laptop slightly.
    • Holding the laptop open, remove three 4 mm screws from each hinge (6 total) using a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  14. Samsung NP-QX411L Screen Replacement: stap 14, afbeelding 1 van 1
    • Hold hinges in place with your thumb and slide the laptop away from the screen.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung NP-QX411L Screen Replacement: stap 15, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement: stap 15, afbeelding 2 van 2
    • Remove the 4 rubber stoppers with the precision tweezers.
    Vraag FixBot
    Voeg opmerking toe
  16. Samsung NP-QX411L Screen Replacement: stap 16, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement: stap 16, afbeelding 2 van 2
    • Remove the four 4 mm screws with a Phillips #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  17. Samsung NP-QX411L Screen Replacement: stap 17, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement: stap 17, afbeelding 2 van 2
    • The metal spudger could scratch the screen.
    • Wedge the metal spudger underneath the cover and run it along the edges. Gently pry the cover up.
    Vraag FixBot
    Voeg opmerking toe
  18. Samsung NP-QX411L Screen Replacement: stap 18, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement: stap 18, afbeelding 2 van 2
    • Remove the three 4 mm screws on each hinge with a Phillips #000 screwdriver. There should be a total of 6 screws to remove.
    Vraag FixBot
    Voeg opmerking toe
  19. Samsung NP-QX411L Screen Replacement, Screen: stap 19, afbeelding 1 van 2 Samsung NP-QX411L Screen Replacement, Screen: stap 19, afbeelding 2 van 2
    • Remove the four 4 mm screws using Phillips #000 screwdriver.
    • Remove metal brackets.
    Vraag FixBot
    Voeg opmerking toe
  20. Samsung NP-QX411L Screen Replacement: stap 20, afbeelding 1 van 1
    • Use the small suction cup to lift the screen.
    • Disconnect the wire by pulling it away from the bottom of the screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Rebecca Johnson
594 Reputatie
5 handleidingen geschreven
USF Tampa, Team S19-G3, Hoffman Spring 2017 Lid van USF Tampa, Team S19-G3, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G3
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 27
Altijd: 1,420
