Ga door naar hoofdinhoud
Samsung Level Box Mini Battery Replacement
Wat je nodig hebt
  1. Samsung Level Box Mini Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Level Box Mini Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using a plastic opening tool, go around the edges of the rubber bottom. Insert the same tool under the edge of the rubber and swivel side to side. Continue moving it forward while peeling the plastic off with the precision tweezers.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Level Box Mini Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the six 4.5 mm Philips #1 screws from the bottom plate using the Screwdriver J00. Take off the bottom plate.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Level Box Mini Battery Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic opening tool, remove the batteries from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow all the instructions in the reverse order. Use adhesive to stick the rubber back onto the bottom of the device.
9 andere personen hebben deze handleiding voltooid.
dylan weiss
134 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-4, Kass Spring 2017 Lid van USF Tampa, Team 1-4, Kass Spring 2017
USFT-KASS-S17S1G4
5 Leden
4 handleidingen geschreven
5Gids Commentaar
Did all above but still wont switch on..batt are ok and power gets to the battery points…what could be wrong…
dslotman5 - Antwoord Deel
I want to replace pcb of this device how to find it??
faraz siddiqui - Antwoord Deel
I want to replace PCB of this device suggest me where to find?
The "parts needed" list has a search for the battery misspelled in "Samsung".
Jim Plosay - Antwoord Deel
What kind of batterries should get ?
Aldo Eliezer Rivera Sizzo - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 85
Altijd: 10,234
