Ga door naar hoofdinhoud
Samsung Jack Speaker Replacement
Wat je nodig hebt
  1. Samsung Jack Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Jack Speaker Replacement: stap 2, afbeelding 1 van 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Jack Speaker Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Jack Speaker Replacement: stap 4, afbeelding 1 van 3 Samsung Jack Speaker Replacement: stap 4, afbeelding 2 van 3 Samsung Jack Speaker Replacement: stap 4, afbeelding 3 van 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Jack Speaker Replacement: stap 5, afbeelding 1 van 1
    • Lift the rear case off of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Jack Speaker Replacement, Speaker: stap 6, afbeelding 1 van 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Jack Speaker Replacement: stap 7, afbeelding 1 van 2 Samsung Jack Speaker Replacement: stap 7, afbeelding 2 van 2
    • Use the spudger to detach the speaker ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Jack Speaker Replacement: stap 8, afbeelding 1 van 1
    • Lift the speaker out of its compartment.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Paul Piller
56 Reputatie
5 handleidingen geschreven
Cal Poly, Team 24-57, Amido Spring 2011 Lid van Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 2,076
