Ga door naar hoofdinhoud
Samsung Jack LCD Replacement
Wat je nodig hebt
    1. Samsung Jack LCD Replacement, Battery: stap 1, afbeelding 1 van 1
      • Slide the battery cover downwards with pressure focused on the center of the cover.
      • Lift the cover off of the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack LCD Replacement: stap 2, afbeelding 1 van 1
      • Grasp the bottom left and right corners of the battery and lift it from its housing.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack LCD Replacement, Rear Case: stap 3, afbeelding 1 van 1
      • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack LCD Replacement: stap 4, afbeelding 1 van 3 Samsung Jack LCD Replacement: stap 4, afbeelding 2 van 3 Samsung Jack LCD Replacement: stap 4, afbeelding 3 van 3
      • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool in between the front and rear cases.
      • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack LCD Replacement: stap 5, afbeelding 1 van 1
      • Lift the rear case off of the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack LCD Replacement, Antenna: stap 6, afbeelding 1 van 1
      • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack LCD Replacement: stap 7, afbeelding 1 van 3 Samsung Jack LCD Replacement: stap 7, afbeelding 2 van 3 Samsung Jack LCD Replacement: stap 7, afbeelding 3 van 3
      • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
      • Use a spudger to remove the wire connector under the antenna.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack LCD Replacement, Speaker: stap 8, afbeelding 1 van 1
      • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
      • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack LCD Replacement: stap 9, afbeelding 1 van 2 Samsung Jack LCD Replacement: stap 9, afbeelding 2 van 2
      • Use the spudger to detach the speaker ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack LCD Replacement: stap 10, afbeelding 1 van 1
      • Lift the speaker out of its compartment.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack LCD Replacement, Motherboard: stap 11, afbeelding 1 van 1
      • Remove the power and volume buttons on the right side of the Motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack LCD Replacement: stap 12, afbeelding 1 van 2 Samsung Jack LCD Replacement: stap 12, afbeelding 2 van 2
      • Use a spudger to detach the camera ribbon cable.
      • Lift the camera off of the Motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack LCD Replacement: stap 13, afbeelding 1 van 2 Samsung Jack LCD Replacement: stap 13, afbeelding 2 van 2
      • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Jack LCD Replacement: stap 14, afbeelding 1 van 3 Samsung Jack LCD Replacement: stap 14, afbeelding 2 van 3 Samsung Jack LCD Replacement: stap 14, afbeelding 3 van 3
      • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
      • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Jack LCD Replacement: stap 15, afbeelding 1 van 2 Samsung Jack LCD Replacement: stap 15, afbeelding 2 van 2
      • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
      • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
      • Use a spudger to disconnect the Motherboard ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    6. Samsung Jack LCD Replacement: stap 16, afbeelding 1 van 1
      • Lift the Motherboard off of the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack LCD Replacement, LCD: stap 17, afbeelding 1 van 3 Samsung Jack LCD Replacement, LCD: stap 17, afbeelding 2 van 3 Samsung Jack LCD Replacement, LCD: stap 17, afbeelding 3 van 3
      • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
      • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack LCD Replacement: stap 18, afbeelding 1 van 2 Samsung Jack LCD Replacement: stap 18, afbeelding 2 van 2
      • Lift up the LCD frame.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack LCD Replacement: stap 19, afbeelding 1 van 3 Samsung Jack LCD Replacement: stap 19, afbeelding 2 van 3 Samsung Jack LCD Replacement: stap 19, afbeelding 3 van 3
      • There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
      • Insert the spudger under the bottom left corner of the LCD screen.
      • Use the spudger to gently pry the LCD screen out of its frame.
      • Gently remove the screen from the frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Paul Piller
56 Reputatie
5 handleidingen geschreven
Cal Poly, Team 24-57, Amido Spring 2011 Lid van Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Leden
56 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 2,264
