Ga door naar hoofdinhoud
Samsung Jack Keyboard Replacement
Wat je nodig hebt
    1. Samsung Jack Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Slide the battery cover downwards with pressure focused on the center of the cover.
      • Lift the cover off of the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Grasp the bottom left and right corners of the battery and lift it from its housing.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack Keyboard Replacement, Rear Case: stap 3, afbeelding 1 van 1
      • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack Keyboard Replacement: stap 4, afbeelding 1 van 3 Samsung Jack Keyboard Replacement: stap 4, afbeelding 2 van 3 Samsung Jack Keyboard Replacement: stap 4, afbeelding 3 van 3
      • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool in between the front and rear cases.
      • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack Keyboard Replacement: stap 5, afbeelding 1 van 1
      • Lift the rear case off of the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack Keyboard Replacement, Antenna: stap 6, afbeelding 1 van 1
      • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack Keyboard Replacement: stap 7, afbeelding 1 van 3 Samsung Jack Keyboard Replacement: stap 7, afbeelding 2 van 3 Samsung Jack Keyboard Replacement: stap 7, afbeelding 3 van 3
      • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
      • Use a spudger to remove the wire connector under the antenna.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack Keyboard Replacement, Speaker: stap 8, afbeelding 1 van 1
      • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
      • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack Keyboard Replacement: stap 9, afbeelding 1 van 2 Samsung Jack Keyboard Replacement: stap 9, afbeelding 2 van 2
      • Use the spudger to detach the speaker ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack Keyboard Replacement: stap 10, afbeelding 1 van 1
      • Lift the speaker out of its compartment.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack Keyboard Replacement, Motherboard: stap 11, afbeelding 1 van 1
      • Remove the power and volume buttons on the right side of the Motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack Keyboard Replacement: stap 12, afbeelding 1 van 2 Samsung Jack Keyboard Replacement: stap 12, afbeelding 2 van 2
      • Use a spudger to detach the camera ribbon cable.
      • Lift the camera off of the Motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack Keyboard Replacement: stap 13, afbeelding 1 van 2 Samsung Jack Keyboard Replacement: stap 13, afbeelding 2 van 2
      • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Jack Keyboard Replacement: stap 14, afbeelding 1 van 3 Samsung Jack Keyboard Replacement: stap 14, afbeelding 2 van 3 Samsung Jack Keyboard Replacement: stap 14, afbeelding 3 van 3
      • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
      • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Jack Keyboard Replacement: stap 15, afbeelding 1 van 2 Samsung Jack Keyboard Replacement: stap 15, afbeelding 2 van 2
      • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
      • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
      • Use a spudger to disconnect the Motherboard ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    6. Samsung Jack Keyboard Replacement: stap 16, afbeelding 1 van 1
      • Lift the Motherboard off of the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Jack Keyboard Replacement, Keyboard: stap 17, afbeelding 1 van 3 Samsung Jack Keyboard Replacement, Keyboard: stap 17, afbeelding 2 van 3 Samsung Jack Keyboard Replacement, Keyboard: stap 17, afbeelding 3 van 3
      • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
      • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
      • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Jack Keyboard Replacement: stap 18, afbeelding 1 van 2 Samsung Jack Keyboard Replacement: stap 18, afbeelding 2 van 2
      • Lift up the LCD frame.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Jack Keyboard Replacement: stap 19, afbeelding 1 van 3 Samsung Jack Keyboard Replacement: stap 19, afbeelding 2 van 3 Samsung Jack Keyboard Replacement: stap 19, afbeelding 3 van 3
      • The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard.
      • The keyboard and directional keys are glued separately to the LCD frame.
      • Insert the spudger between the keyboard and the frame.
      • Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Jack Keyboard Replacement: stap 20, afbeelding 1 van 3 Samsung Jack Keyboard Replacement: stap 20, afbeelding 2 van 3 Samsung Jack Keyboard Replacement: stap 20, afbeelding 3 van 3
      • Insert the spudger between the directional keys and the frame.
      • Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jaime Serrano
59 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-57, Amido Spring 2011 Lid van Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Leden
56 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 2,409
