Ga door naar hoofdinhoud
Samsung Jack Antenna Replacement
Wat je nodig hebt
  1. Samsung Jack Antenna Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Jack Antenna Replacement: stap 2, afbeelding 1 van 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Jack Antenna Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Jack Antenna Replacement: stap 4, afbeelding 1 van 3 Samsung Jack Antenna Replacement: stap 4, afbeelding 2 van 3 Samsung Jack Antenna Replacement: stap 4, afbeelding 3 van 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Jack Antenna Replacement: stap 5, afbeelding 1 van 1
    • Lift the rear case off of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Jack Antenna Replacement, Antenna: stap 6, afbeelding 1 van 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Jack Antenna Replacement: stap 7, afbeelding 1 van 3 Samsung Jack Antenna Replacement: stap 7, afbeelding 2 van 3 Samsung Jack Antenna Replacement: stap 7, afbeelding 3 van 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Paul Piller
56 Reputatie
5 handleidingen geschreven
Cal Poly, Team 24-57, Amido Spring 2011 Lid van Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 52
Altijd: 2,704
