Ga door naar hoofdinhoud
Samsung Instinct LCD screen Replacement
Wat je nodig hebt
  1. Samsung Instinct LCD screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Instinct LCD screen Replacement: stap 2, afbeelding 1 van 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Instinct LCD screen Replacement, Back Case: stap 3, afbeelding 1 van 1
    • Remove the four 4.45mm screws at the corners of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Instinct LCD screen Replacement: stap 4, afbeelding 1 van 2 Samsung Instinct LCD screen Replacement: stap 4, afbeelding 2 van 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Instinct LCD screen Replacement: stap 5, afbeelding 1 van 1
    • Lift the casing off of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Instinct LCD screen Replacement, Antenna: stap 6, afbeelding 1 van 1
    • With the screws removed, locate the antenna.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Instinct LCD screen Replacement: stap 7, afbeelding 1 van 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Instinct LCD screen Replacement: stap 8, afbeelding 1 van 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Instinct LCD screen Replacement: stap 9, afbeelding 1 van 1
    • Gently lift up on the antenna and remove it from the back of the device.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Instinct LCD screen Replacement, Front Case: stap 10, afbeelding 1 van 1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Instinct LCD screen Replacement: stap 11, afbeelding 1 van 3 Samsung Instinct LCD screen Replacement: stap 11, afbeelding 2 van 3 Samsung Instinct LCD screen Replacement: stap 11, afbeelding 3 van 3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Instinct LCD screen Replacement: stap 12, afbeelding 1 van 1
    • Lift out the top right ribbon from its slot on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Instinct LCD screen Replacement: stap 13, afbeelding 1 van 2 Samsung Instinct LCD screen Replacement: stap 13, afbeelding 2 van 2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
    Vraag FixBot
    Voeg opmerking toe
  14. Samsung Instinct LCD screen Replacement: stap 14, afbeelding 1 van 1
    • Lift the motherboard away from the front casing.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung Instinct LCD screen Replacement: stap 15, afbeelding 1 van 1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
    Vraag FixBot
    Voeg opmerking toe
  16. Samsung Instinct LCD screen Replacement, LCD screen: stap 16, afbeelding 1 van 1
    • Using the plastic opener tool, detach the ribbon located on the bottom of the phone below the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  17. Samsung Instinct LCD screen Replacement: stap 17, afbeelding 1 van 1
    • Lift the microchip (located at the bottom of the phone) and insert the plastic opener tool under the screen.
    • Lift up the screen. The microchip is attached to the screen and will be lifted out with the screen.
    Vraag FixBot
    Voeg opmerking toe
  18. Samsung Instinct LCD screen Replacement: stap 18, afbeelding 1 van 1
    • After lifting out the LCD screen, the screen and its housing should be separated as shown.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick
75 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-13, Regan Fall 2011 Lid van Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Leden
32 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 1,918
