Ga door naar hoofdinhoud
Samsung Impression LCD Flex Cable Replacement
Wat je nodig hebt
  1. Samsung Impression LCD Flex Cable Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Impression LCD Flex Cable Replacement: stap 2, afbeelding 1 van 2 Samsung Impression LCD Flex Cable Replacement: stap 2, afbeelding 2 van 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Impression LCD Flex Cable Replacement, Back Cover: stap 3, afbeelding 1 van 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Impression LCD Flex Cable Replacement: stap 4, afbeelding 1 van 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Impression LCD Flex Cable Replacement, Circuit Board: stap 5, afbeelding 1 van 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Impression LCD Flex Cable Replacement: stap 6, afbeelding 1 van 2 Samsung Impression LCD Flex Cable Replacement: stap 6, afbeelding 2 van 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Impression LCD Flex Cable Replacement, Keyboard: stap 7, afbeelding 1 van 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Impression LCD Flex Cable Replacement: stap 8, afbeelding 1 van 2 Samsung Impression LCD Flex Cable Replacement: stap 8, afbeelding 2 van 2
    • Remove the six 2.7 mm screws holding the silver plate on and set aside (fig. 1).
    • Separate the silver plate and phone frame (fig. 2).
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Impression LCD Flex Cable Replacement: stap 9, afbeelding 1 van 1
    • The silver piece you are left with is the physical keyboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Impression LCD Flex Cable Replacement, LCD Flex Cable: stap 10, afbeelding 1 van 2 Samsung Impression LCD Flex Cable Replacement, LCD Flex Cable: stap 10, afbeelding 2 van 2
    • Remove the 3 screws holding down the flex cable.
    • The two screws on the black frame are 2.0 mm in length.
    • The top right screw that goes through the circle port on the flex cable is 2.3 mm.
    • Remove the keyboard slider frame. The flex cable should be exposed, but not free.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Impression LCD Flex Cable Replacement: stap 11, afbeelding 1 van 1
    • Remove the four 3.5 mm outer screws.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Impression LCD Flex Cable Replacement: stap 12, afbeelding 1 van 3 Samsung Impression LCD Flex Cable Replacement: stap 12, afbeelding 2 van 3 Samsung Impression LCD Flex Cable Replacement: stap 12, afbeelding 3 van 3
    • Slide the phone apart and remove the 3.5 mm screw on the top middle (fig. 1).
    • Remove the outer shell by prying the edges off with your fingers or a small screwdriver (fig. 2).
    • The device will now be in two pieces (fig. 3).
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Impression LCD Flex Cable Replacement: stap 13, afbeelding 1 van 2 Samsung Impression LCD Flex Cable Replacement: stap 13, afbeelding 2 van 2
    • Lift the tab underneath the blue tape and gently pull the flex cable (fig. 1).
    • The flex cable will now be completely free (fig. 2).
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Saul Villatoro
260 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2011 Lid van Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Leden
45 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 38
Altijd: 7,883
