Ga door naar hoofdinhoud
Samsung Impression Camera Replacement
Wat je nodig hebt
    1. Samsung Impression Camera Replacement, Battery: stap 1, afbeelding 1 van 1
      • Orient the phone with the screen facing downward.
      • Slide the panel away from the camera using your thumb. This will expose the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Impression Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Impression Camera Replacement: stap 2, afbeelding 2 van 2
      • Insert the tip of the spudger on the left side of the battery.
      • Pry the battery out. It will pivot in the direction of the white arrow.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Impression Camera Replacement, Back Cover: stap 3, afbeelding 1 van 1
      • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Impression Camera Replacement: stap 4, afbeelding 1 van 1
      • Gently pry around the edges with the spudger to remove back panel.
      • It may help to slide the touchscreen upwards when removing the back panel.
      • The side buttons will become loose and will fall out, so put these in a safe place.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Impression Camera Replacement, Circuit Board: stap 5, afbeelding 1 van 1
      • Gently remove the black wire to free the circuit board.
      • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Impression Camera Replacement: stap 6, afbeelding 1 van 2 Samsung Impression Camera Replacement: stap 6, afbeelding 2 van 2
      • Gently tug the black and blue ribbon upwards to release the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Impression Camera Replacement, Camera: stap 7, afbeelding 1 van 2 Samsung Impression Camera Replacement, Camera: stap 7, afbeelding 2 van 2
      • Turn the circuit board over.
      • The bottom of the camera will have a gold ribbon coming out of it which attaches to the circuit board.
      • Pull upwards on the blue rectangle where the gold ribbon ends. This will remove the camera from the circuit board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Saul Villatoro
260 Reputatie
7 handleidingen geschreven
Cal Poly, Team 8-10, Regan Spring 2011 Lid van Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Leden
132 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 1,942
