Ga door naar hoofdinhoud
Samsung Gravity TXT Screen Replacement
Wat je nodig hebt
  1. Samsung Gravity TXT Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Gravity TXT Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Gravity TXT Screen Replacement: stap 2, afbeelding 1 van 1
    • Lift the back cover away from the main body of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Gravity TXT Screen Replacement: stap 3, afbeelding 1 van 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Gravity TXT Screen Replacement, SIM Card: stap 4, afbeelding 1 van 3 Samsung Gravity TXT Screen Replacement, SIM Card: stap 4, afbeelding 2 van 3 Samsung Gravity TXT Screen Replacement, SIM Card: stap 4, afbeelding 3 van 3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Gravity TXT Screen Replacement, microSD Card: stap 5, afbeelding 1 van 3 Samsung Gravity TXT Screen Replacement, microSD Card: stap 5, afbeelding 2 van 3 Samsung Gravity TXT Screen Replacement, microSD Card: stap 5, afbeelding 3 van 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Gravity TXT Screen Replacement, Plastic Back Frame: stap 6, afbeelding 1 van 1
    • Remove the six 3 mm #00 Phillips screws in the plastic back frame.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Gravity TXT Screen Replacement: stap 7, afbeelding 1 van 3 Samsung Gravity TXT Screen Replacement: stap 7, afbeelding 2 van 3 Samsung Gravity TXT Screen Replacement: stap 7, afbeelding 3 van 3
    • Slide the keyboard out.
    • Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
    • Starting at the bottom of the keyboard is recommended.
    • Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
    • You will have to slide the keyboard back in to separate the back frame from the top have of the keyboard slider.
    • Lift the plastic back frame away.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Gravity TXT Screen Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
    • Do not try to pull the motherboad out just yet. The display data cable needs to be disconnected from the motherboad first.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Gravity TXT Screen Replacement: stap 9, afbeelding 1 van 3 Samsung Gravity TXT Screen Replacement: stap 9, afbeelding 2 van 3 Samsung Gravity TXT Screen Replacement: stap 9, afbeelding 3 van 3
    • Use your finger nail to disconnect the display data cable from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Gravity TXT Screen Replacement: stap 10, afbeelding 1 van 2 Samsung Gravity TXT Screen Replacement: stap 10, afbeelding 2 van 2
    • Carefully lift the main motherboard assembly away from the front panel.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Gravity TXT Screen Replacement, Keyboard: stap 11, afbeelding 1 van 1
    • Take the keyboard off of the phone.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Gravity TXT Screen Replacement, Screen: stap 12, afbeelding 1 van 3 Samsung Gravity TXT Screen Replacement, Screen: stap 12, afbeelding 2 van 3 Samsung Gravity TXT Screen Replacement, Screen: stap 12, afbeelding 3 van 3
    • Lift the ribbon off the plastic inner frame.
    • You may have to warm the adhesive using an iOpener to avoid damaging the ribbon.
    • Remove the six 1.2 mm #00 screws from the inner plastic frame.
    • Slide the ribbon through the slot on the inner frame while pulling the frame away.
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Gravity TXT Screen Replacement: stap 13, afbeelding 1 van 1
    • Remove the four 2.4 mm #00 Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  14. Samsung Gravity TXT Screen Replacement: stap 14, afbeelding 1 van 3 Samsung Gravity TXT Screen Replacement: stap 14, afbeelding 2 van 3 Samsung Gravity TXT Screen Replacement: stap 14, afbeelding 3 van 3
    • Use a opening pick to separate the plastic back casing from the front of the phone by running it along the seam between the two.
    • Lift casing slightly away while sliding the ribbon through the slot in the casing.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung Gravity TXT Screen Replacement: stap 15, afbeelding 1 van 2 Samsung Gravity TXT Screen Replacement: stap 15, afbeelding 2 van 2
    • Use a spudger to get underneath and remove the call speaker.
    Vraag FixBot
    Voeg opmerking toe
  16. Samsung Gravity TXT Screen Replacement: stap 16, afbeelding 1 van 2 Samsung Gravity TXT Screen Replacement: stap 16, afbeelding 2 van 2
    • Remove the plastic adhesive sheet to expose the ribbon cables
    • The use of an iOpener may be needed to soften the eadhesive
    • Use your finger or a spudger to pull the screen ribbon out of the connector
    Vraag FixBot
    Voeg opmerking toe
  17. Samsung Gravity TXT Screen Replacement: stap 17, afbeelding 1 van 3 Samsung Gravity TXT Screen Replacement: stap 17, afbeelding 2 van 3 Samsung Gravity TXT Screen Replacement: stap 17, afbeelding 3 van 3
    • Use a Jimmy to separate the screen from the rest of the phone
    • You may need to heat the perimeter of the screen with an iOpener to soften the adhesive.
    • Lift the screen away
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Sieverding
186 Reputatie
1 Handleiding geschreven
IUPUI, Team 1-1, Renguette SU 2015 Lid van IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Leden
32 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 1,232
