Inleiding
This replacement may be necessary to repair a device with severe hardware issues. This replacement can resolve problems such as signal failure or a phone that won't turn on. However, this repair may erase all data, so be sure to back up your information beforehand. You will need a Phillips #00 Screwdriver for this replacement.
Wat je nodig hebt
Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
Using your fingers, take the case off.
