Ga door naar hoofdinhoud
Samsung Gear VR USB Connector Replacement
    1. Samsung Gear VR USB Connector Replacement, USB Connector Replacement: stap 1, afbeelding 1 van 1
      • Remove front cover from headset.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Gear VR USB Connector Replacement: stap 2, afbeelding 1 van 1
      • Slide the latch to the right to unlock the current connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Gear VR USB Connector Replacement: stap 3, afbeelding 1 van 2 Samsung Gear VR USB Connector Replacement: stap 3, afbeelding 2 van 2
      • Lift connector clip away from headset and towards you.
      • Slide current connector out and away from headset until it is disconnected from connector clip.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Gear VR USB Connector Replacement: stap 4, afbeelding 1 van 1
      • Select which connector fits the port of the device you wish to use with the Samsung Gear VR.
      • The Samsung Gear VR is packaged with connectors for Micro USB and USB-C.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Gear VR USB Connector Replacement: stap 5, afbeelding 1 van 2 Samsung Gear VR USB Connector Replacement: stap 5, afbeelding 2 van 2
      • Slide the connector that connects to your device back onto the connector clip until you feel it settle into place.
      • Slide the lock latch to the left to secure the connector into place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alfredo Aparicio
325 Reputatie
3 handleidingen geschreven
USF Tampa, Team S4-G6, Eyestone Fall 2017 Lid van USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Leden
14 handleidingen geschreven
5Gids Commentaar
Hola, quisiera saber donde se consigue esa parte, ni siquiera en samsung lo he logrado
Jose Davinci - Antwoord Deel
Were do I get the USB c adapter
helenpaul77 - Antwoord Deel
If you want USB c adapter I can give you…but we have to make exchange because I need micro usb adapter not type c
Molefi Aaron - Antwoord Deel
I have the micro USB adapter and need type c. Please advise as to how this barter may be executed?
Saleem A. Sheikh - Antwoord Deel
Where can I get micro USB converter for gear vr not type c
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 98
Altijd: 18,240
