Ga door naar hoofdinhoud
Samsung Gear S Home Button Assembly Replacement
Wat je nodig hebt
    1. Samsung Gear S Home Button Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 3 Samsung Gear S Home Button Assembly Replacement, Display Assembly: stap 1, afbeelding 2 van 3 Samsung Gear S Home Button Assembly Replacement, Display Assembly: stap 1, afbeelding 3 van 3
      • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Gear S Home Button Assembly Replacement: stap 2, afbeelding 1 van 2 Samsung Gear S Home Button Assembly Replacement: stap 2, afbeelding 2 van 2
      • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
      • Some force is needed due to adhesive seal.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Gear S Home Button Assembly Replacement: stap 3, afbeelding 1 van 1
      • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung Gear S Home Button Assembly Replacement: stap 4, afbeelding 1 van 1
      • Locate the ribbon assembly attaching the display to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung Gear S Home Button Assembly Replacement: stap 5, afbeelding 1 van 1
      • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Samsung Gear S Home Button Assembly Replacement: stap 6, afbeelding 1 van 1
      • Now the watch should be in three separate pieces.
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: stap 7, afbeelding 1 van 2 Samsung Gear S Home Button Assembly Replacement, Home Button Assembly: stap 7, afbeelding 2 van 2
      • Locate the home ribbon connector attached to the wrist side (side that faces the user when wearing it) of the motherboard assembly.
      • Locate the home ribbon assembly attached to the screen side of the motherboard assembly.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung Gear S Home Button Assembly Replacement: stap 8, afbeelding 1 van 1
      • Use a plastic opening tool to gently pry up on the home ribbon connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung Gear S Home Button Assembly Replacement: stap 9, afbeelding 1 van 1
      • Use the spudger to pry up the home ribbon assembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Luis Franco
1.076 Reputatie
4 handleidingen geschreven
USF Tampa, Team 12-1, Blackwell Fall 2015 Lid van USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Leden
25 handleidingen geschreven
2Gids Commentaar
where can i buy the home buton?
Hanna Iskandar - Antwoord Deel
I am in search of the SM-R750v Housing Back Cover, any suggestions
Rita Arnold - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 39
Altijd: 5,675
