Inleiding
This guide shows how to remove the display of the watch from the rest of the watch.
Wat je nodig hebt
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
19 andere personen hebben deze handleiding voltooid.
16Gids Commentaar
Where can i get the LCD for Gear S
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
My watch is doing the same thing. Did you get a fix for it?
