Ga door naar hoofdinhoud
Samsung Galaxy Y Charging port and headphone jack Replacement
Wat je nodig hebt
  1. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: stap 1, afbeelding 1 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: stap 1, afbeelding 2 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: stap 2, afbeelding 1 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: stap 2, afbeelding 2 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: stap 2, afbeelding 3 van 3
    • Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y Charging port and headphone jack Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 3, afbeelding 3 van 3
    • Use metal pry tool to separate the interior back panel from the interior hardware and screen.
  4. Samsung Galaxy Y Charging port and headphone jack Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the orange motherboard connection, then remove interior hardware from the front screen display.
  5. Samsung Galaxy Y Charging port and headphone jack Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
    • If the motherboard is cracked or damaged, then replace with a new one.
  6. Samsung Galaxy Y Charging port and headphone jack Replacement: stap 6, afbeelding 1 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 6, afbeelding 2 van 3 Samsung Galaxy Y Charging port and headphone jack Replacement: stap 6, afbeelding 3 van 3
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alyissa
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 652
