Ga door naar hoofdinhoud
Samsung Galaxy View Kickstand Replacement
Wat je nodig hebt
  1. Samsung Galaxy View Kickstand Replacement, Kickstand: stap 1, afbeelding 1 van 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Galaxy View Kickstand Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy View Kickstand Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy View Kickstand Replacement: stap 2, afbeelding 3 van 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jordan Thayer
535 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-5, Livingston Fall 2016 Lid van Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Leden
12 handleidingen geschreven
15Gids Commentaar
Where do u buy a replacement kickstand
Bethann Stokes - Antwoord Deel
The only thing I could find was a broken one on eBay for parts ......
cindylou73 - Antwoord Deel
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 48
Altijd: 9,591
