Ga door naar hoofdinhoud
Samsung Galaxy View Battery Replacement
Wat je nodig hebt
  1. Samsung Galaxy View Battery Replacement, Kickstand: stap 1, afbeelding 1 van 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Galaxy View Battery Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 2, afbeelding 3 van 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Galaxy View Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Samsung Galaxy View Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Check the device is completely turned off.
    • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Galaxy View Battery Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 4, afbeelding 3 van 3
    • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Galaxy View Battery Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
    • Insert the metal spudger within the opening.
    • Move the metal spudger down the seam, prying the back panel open as you go.
    • Once a large enough opening is made, pry the entire back panel off with your hand.
    • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Galaxy View Battery Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy View Battery Replacement: stap 6, afbeelding 2 van 2
    • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Galaxy View Battery Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy View Battery Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy View Battery Replacement: stap 7, afbeelding 3 van 3
    • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
    • Remove the battery from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
40 andere personen hebben deze handleiding voltooid.
Roger Pena
1.141 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-5, Livingston Fall 2016 Lid van Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Leden
12 handleidingen geschreven
29Gids Commentaar
I’m not sure if it’s the battery or the cord
Swheet - Antwoord Deel
What size is the battery that fits into the SAMSUNG TAB VIEW?
Ricky Lee Lidel - Antwoord Deel
Thank You, Sooo much. This guide is a true money and time saver. Worked like a gem .
Mike Rowe - Antwoord Deel
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Sue ELLEN R FONTENOT - Antwoord Deel
Where can I find battery replacement for galaxy view
Greg Dover - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 76
Altijd: 27,831
