Ga door naar hoofdinhoud
Samsung Galaxy Tab S 8.4 Back Cover Replacement
Wat je nodig hebt
  1. Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 2 Samsung Galaxy Tab S 8.4 Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
    Will a butter knife work?
    Team Diamond (DrDiamond53) - Antwoord
    You could try a credit card, avoid metal tools.
    Isaac Pettis -
    The battery is still connected at this stage so, yes, avoid metal tools.
    Once the outer frame was mostly unclipped with the opening tool, I found the ifixit triangle plastic picks useful. As well as clips around the 4 edges there are maybe 4 more clips in the centre of the back cover that are a challenge.
    Make sure the display screen and logic boards and battery all come out in one bundle, just leaving a bare plastic back shell. Others have reported that if you separate the screen from the boards you’ll invariably break a ribbon cable and lose touch sensitivity.
    Michael Morjanoff - Antwoord
  2. Samsung Galaxy Tab S 8.4 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Remove the back cover after the entire rim is disconnected.
    I did some diy fixing because my tab-s came having issues. All battery connection related. Easy fix about 10 minutes but now the back cover won't sit flush and there's a large gap…idk what to do now it's infuriating there no broken tabs or connections
    Jason Carlson - Antwoord
Conclusie
12 andere personen hebben deze handleiding voltooid.
Tara Fussell
996 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-15, Maness Fall 2015 Lid van Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Leden
12 handleidingen geschreven
3Gids Commentaar
This is great and the process works fine. The query is where does one purchase a new back cover
Alan - Antwoord
Hi, where can I buy the back cover of Samsung galaxy tab S 8.4. Tnx
Abe Madrigal - Antwoord
Hi, where can I buy the back cover of Samsung galaxy tab s 8.4. Ty
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 66
Altijd: 13,736
