Inleiding
This replacement guide will show you how to replace the charging port in your Samsung Galaxy Tab E Lite 7 Kids. You will need to follow the instructions carefully as to not damage any fragile components in your tablet.
Wat je nodig hebt
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
Use your hands to pull the black cable out of its slot.
Use a soldering iron to heat 4 spots of solder from the motherboard.
Use precision tweezers to remove the charging port.
Één andere persoon heeft deze handleiding voltooid.
