Ga door naar hoofdinhoud
Samsung Galaxy S6 Edge+ Midframe Replacement
Wat je nodig hebt
  1. Samsung Galaxy S6 Edge+ Midframe Replacement, Rear Glass: stap 1, afbeelding 1 van 1
    • Heat an iOpener and apply it to the volume button side of the phone for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S6 Edge+ Midframe Replacement: stap 2, afbeelding 1 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 2, afbeelding 2 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 2, afbeelding 3 van 3
    • Once the back panel is hot to the touch, apply a suction cup near the center of the phone, and as close as possible to the edge of the panel.
    • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
  3. Samsung Galaxy S6 Edge+ Midframe Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 3, afbeelding 3 van 3
    • Slide the pick along the side of the phone to cut the adhesive securing the rear panel.
    • Go slowly so that the pick doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener.
  4. Samsung Galaxy S6 Edge+ Midframe Replacement: stap 4, afbeelding 1 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 4, afbeelding 2 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 4, afbeelding 3 van 3
    • Repeat the heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick under each edge to prevent the adhesive from resealing.
  5. Samsung Galaxy S6 Edge+ Midframe Replacement: stap 5, afbeelding 1 van 2 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 5, afbeelding 2 van 2
    • Use an opening pick to slice through any remaining adhesive.
    • Remove the rear glass.
  6. Samsung Galaxy S6 Edge+ Midframe Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $5.99
    Koop
    • To reinstall the back cover:
    • First use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
    • Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. The sheet is asymmetrical, so make sure the screw holes in the adhesive sheet line up with the screws on the frame before applying the adhesive.
    • If the adhesive sheet is not available, you can use a high-bond double-sided tape, such as Tesa 61395.
    • After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
  7. Samsung Galaxy S6 Edge+ Midframe Replacement, Midframe: stap 7, afbeelding 1 van 1
    • Remove eighteen 3.2 mm screws from the midframe.
  8. Samsung Galaxy S6 Edge+ Midframe Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy S6 Edge+ Midframe Replacement: stap 8, afbeelding 3 van 3
    • Press down on the back of the battery while you lift up on the edges of the midframe to separate the midframe from the rest of the phone.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Adam O'Camb
196.710 Reputatie
416 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 25
Altijd: 1,429
