Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
The clear rubber backing of the home button assembly is lightly adhered to the back of the display. The adhesive should be easy to cut through with an opening tool. If you have trouble removing the assembly in the following steps, try heating the area using an iOpener or a hair dryer to loosen the adhesive.
Insert either end of an opening tool into the gap between the white rubber backing of the home button assembly and the screen.
Work your way around the bottom edge of the button, gently cutting through the adhesive holding it in place.
Once most of the adhesive around the bottom of the button has been broken, use your opening tool to pry it up.
Grab the lifted portion of the home button assembly and gently pull it away from the display, tearing the rest of the adhesive.
8 andere personen hebben deze handleiding voltooid.
