Ga door naar hoofdinhoud
Samsung Galaxy S Blaze Motherboard Replacement
Wat je nodig hebt
  1. Samsung Galaxy S Blaze Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove the battery cover from the device.
  2. Samsung Galaxy S Blaze Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the device.
  3. Samsung Galaxy S Blaze Motherboard Replacement: stap 3, afbeelding 1 van 2 Samsung Galaxy S Blaze Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame. The screws can be removed in any order.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use the blue plastic opening tool to remove the frame from the device.
    • Work around the device with the opening tool until the frame is completely off the device.
    • You may need to use some force to pry the frame off of the device.
  5. Samsung Galaxy S Blaze Motherboard Replacement: stap 5, afbeelding 1 van 3 Samsung Galaxy S Blaze Motherboard Replacement: stap 5, afbeelding 2 van 3 Samsung Galaxy S Blaze Motherboard Replacement: stap 5, afbeelding 3 van 3
    • The motherboard is held onto the device by 4 ribbon cable connectors.
    • The first 3 ribbon cable connectors are on the same side.
    • Unlatch the first 3 ribbon cable connectors with the blue plastic opening tool.
  6. Samsung Galaxy S Blaze Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Turn the motherboard over to reveal the last ribbon cable connector.
    • Unlatch the final ribbon cable connector with the blue plastic opening tool.
    • Remove the motherboard from the device.
Conclusie
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 andere personen hebben deze handleiding voltooid.
Rene Bolanos
435 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 800
