Ga door naar hoofdinhoud
Samsung Galaxy J3 (2016) SIM Card Replacement
Wat je nodig hebt
  1. Samsung Galaxy J3 (2016) SIM Card Replacement, Rear Cover: stap 1, afbeelding 1 van 2 Samsung Galaxy J3 (2016) SIM Card Replacement, Rear Cover: stap 1, afbeelding 2 van 2
    • Insert a fingernail or the flat end of a spudger into the divot to the left of the rear-facing camera.
    • Gently pry the rear cover away from the phone until all the plastic clips holding the cover are released.
  2. Samsung Galaxy J3 (2016) SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the rear cover.
    • To reinstall the rear cover, align it to the back of the phone, and squeeze the perimeter of the phone to snap all the clips into place.
  3. Samsung Galaxy J3 (2016) SIM Card Replacement, Battery: stap 3, afbeelding 1 van 3 Samsung Galaxy J3 (2016) SIM Card Replacement, Battery: stap 3, afbeelding 2 van 3 Samsung Galaxy J3 (2016) SIM Card Replacement, Battery: stap 3, afbeelding 3 van 3
    • Insert a fingernail or the flat end of a spudger into the divot below the battery pack.
    • Pry the battery pack out of its recess.
    • If you use the spudger, do not push too hard or you will puncture the battery pack.
    • Remove the battery pack.
  4. Samsung Galaxy J3 (2016) SIM Card Replacement, SIM Card: stap 4, afbeelding 1 van 3 Samsung Galaxy J3 (2016) SIM Card Replacement, SIM Card: stap 4, afbeelding 2 van 3 Samsung Galaxy J3 (2016) SIM Card Replacement, SIM Card: stap 4, afbeelding 3 van 3
    • Use a fingertip to slide the MicroSD card out of its slot.
    • Remove the MicroSD card from the phone.
    • Repeat the procedure to remove the SIM card from its slot.
    • During reinstallation, make sure the MicroSD and SIM card are properly oriented. Each card will install in only one direction.
Conclusie
Repair didn’t go as planned? Check out our Samsung Galaxy J3 (2016) Answers community for troubleshooting help.
3 andere personen hebben deze handleiding voltooid.
Arthur Shi
221.922 Reputatie
441 handleidingen geschreven
iFixit Lid van iFixit
Community
141 Leden
17.743 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 283
Altijd: 15,285
